So I just received my asus rog swift pro pg248qp that runs at 500hz and went to set it up and plugged it into the HDMI Pass through Port of my Elgato HD60 Pro and no dice, HDMI 2.0 just wont run past 240 hz so Monitor wont turn on.
If I plug directly into my GPU via the latest display port, 500hz no issues but now I have the problem of not being connected to my capture card.
Can anyone recommend a solution where I can play at 500hz but still stream on my HD60Pro at 60 FPS? I was thinking if I still kept the direct connection with display port to the GPU, and then also run an HDMI 2.0 cable from my GPU into the HDMI input on my Capture card- would that still work? If it did would it affect performance having 2 output cables Displayport and HDMI running from my 4090 GTX?
Any recommendations really appreciated!
