Best way to switch out motherboard
tmarmstr
7
Hey so I need to switch out my motherboard. Will this require me to reinstall things? Will my windows license work on the new computer? Are there things I can do that will make it so I have less work to do re-setting things up.
Thanks!
If you're swapping out with an identical motherboard, it should work without a hitch. If you're using a new/different motherboard, you will likely be required to re-install Windows. If you're using any OEM version of Windows 7, you will need to purchase a new license as the current license is tied to your motherboard. If you are using any Retail version of Windows 7 or any version of Windows 8 (OEM or Retail), you can re-install without without issue.
-Wolf sends
