I was dismantling an old rig and one of the mobo spacers was stripped so I had to use pliers to help remove it.... I lightly scratched the back of the mobo about half an inch across. This mobo wont be used anymore (unless I want to build a media machine or something down the road) but I'd still like to know if it is a brick.
What do you guys recommend I do? Rebuild and test it or just chuck it out. I am unaware as to the resiliency of mobos...
If the best bet is to test it, what are the minimum requirements I need to test it's functionality... I have an extra of everything to test it with except a hard drive...
Motherboard in question is an Asrock 990FX Extreme 3
