I recently got my hands on a 3930k and a sabertooth motherboard with it. The problem is when i get it to launch on all the same components as my working pc, it launches all the way up to the windows loading and BSODs with different errors every time. ex0xc000021a , 0xc000007b , CRITICAL PROCESS HAD DIED. and a few others i didn't get to list.
Eventually though it corrupts the hard drive, so that on boot it then starts to do a windows repair instead, and still continues to bsod.
Basically i just want to know if theres any decent way to test either component, without having another cpu/motherboard in hand. And if there is no other way, will it pose a threat to other peoples components if i do try running them with my faulty ones? Thank you for reading!
