Hello friends. My questions simple enough. I have a decent mid-range build, but The Witcher 3
has some pretty crazy specs, so I was hoping to upgrade my computer in any small way I can Im assuming the upgrade would come to CPU or GPU.
PS: My CPU and GPU are both AMD. I've heard it said games arent as well optimized for AMD cards and was wondering how true this statement was, and if it is how much of an impact it really has on performance. Thanks in advance.
Here's my build:
CPU: AMD FX 6350,6 core, [3.9GHz, overclocks to 4.2] (I havent clocked it)
GPU: AMD Radeon R7 260X
RAM: 8GB
1TB HDD, no SSD, solid mobo and power supply, not that those will really come into play when running a game. Thanks for the help.
Minimum and recommended Witcher 3 specs:
Minimum System Requirements:
Intel CPU Core i5-2500K 3.3GHz OR AMD CPU Phenom II X4 940
Nvidia GPU GeForce GTX 660 OR AMD GPU Radeon HD 7870
RAM 6GB
Recommended System Requirements:
Intel CPU Core i7 3770 3,4 GHz OR AMD CPU AMD FX-8350 4 GHz
Nvidia GPU GeForce GTX 770 OR AMD GPU Radeon R9 290
RAM 8GB
Here's my build:
RAM: 8GB
RAM 6GB
RAM 8GB
