Question Best way to upgrade my PC from GT 730 Card?
York_2
8
I bought a PC several years ago - Acer Aspire T3-710 Desktop PC. It has an NVIDIA GeForce GT 730 graphics card. The CPU is an Intel Core i5-6400 2.7GHz. It has 8GB DDR3 expandable to 16GB. Power supply is 220 watts.
I only play WoW TBC Classic and get between 20-30 fps on lowest settings in a raiding environment which really isn't great. I would like to improve that (while also spending the least amount of money).
My questions is: What graphics card do i buy to improve fps?
Thanks in advance for any feedback.
The only viable card you can upgrade to is a GTX 1050 that doesn't require additional PCIe power. And even then, I'm not comfortable throwing a 75W card on this system.
Otherwise you have to upgrade the power supply first.
what other graphics cards could i upgrade to if i were to upgrade the power supply as well?
