Best wireless controller for Gaming? (with long range)
Zablon
20
Hi im searching for a controller for my pc , I actually have a Logitech F710 but It some times doesn't work properly so I'm now using a ps3 controller using a bluetooth dongle,
The problem is I'm going to move my pc to my bedroom but I will be still playing the games in the Tv room thats a distance of 15 feet (with a wall) I tested the F710 range it doesn't get there (although in the specifications it says it has a 30 ft range) same with the ps3 controller
I am thinking of the wireless Xbox 360 controller for PC that has a range of 30ft but I don't know if the receiver will make it or is there a powerful bluetooth dongle that make that distance?
Thanks
You may just want to get a long USB cable so you can take your Wireless Dongle into the next room. I doubt any wireless controllers are meant to work through walls. Especially if your pS3 controller cant do it as ps3 is bluetooth.
