Archived from groups: comp.periphs.printers (
More info?)
how do you like the photo quality?
should i get it if i'm going to be printing ever so oftenn? i heard
that unless you use the phaser 8400 all the time, it wastes ink when
you start it up..
On Sat, 24 Jul 2004 09:50:41 +0100, Timothy Lee <me@privacy.net>
wrote:
>In message <gbc3g0hvb97id4dr6es18nund07vfg6k4m@4ax.com>, Hecate
><hecate@newsguy.com> writes
>>On 23 Jul 2004 07:17:40 -0700, j_le_bru@excite.com (JC) wrote:
>>>Anybody recommend a decent printer upto 400 GBP.
>>>Priorities are cheap running costs. PPM not so important. Needs to
>>>have a reasonable dpi (1200 or so?)
>>>Recommendations Appreciated
>>The Oki and the Samsung are about £450, the HP is about £550.
>>However, if priorities are cheap running costs you need a more
>>expensive printer <g> One of the Kyocera range. They are far cheaper
>>to run than any of the others and give good consistent results. Only
>>problem is that you have to pay about 3 times the amount you say.
>>Also, for the price, you're unlikely to get anything much above
>>600dpi, I think.
>As above you need to consider not only the purchase price but the
>running costs and generally you will get lower running costs with a
>higher initial price. The Kyoceras do seem to have about the cheapest
>running costs. I'm also quite partial to my Xerox solid ink jobby which
>apart from dropping lumps of ink into it the only other replacement part
>is every 40,000 pages, whereas the lower cost conventional colour lasers
>are rather more often changing oil rollers, opc drum kits, waste toners
