my cpu temps are really high about 80 degrees playing a game im using the stock cooler
I wanted to khow if i should buy case fans or a aftermarket cpu cooler ?
which would be a better choice for me btw i have the athol x4 860k cpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103052
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
also if its better to get a cpu cooler which would be the best cooler around 20-30$ range thanks 😀
or
