Better CPU for my Low Budget Workbench
ToKiiNz
138
this is my new low budget workbench i'm building for video editing and rendering to replace my x4 965 and gtx 460. i do some light gaming in skyrim and some battlefield 3 but mostly my skyrim addiction
my 2 choices are the
Xeon E3-1220 v2 http://www.newegg.com/Product/Product.aspx?Item=N82E16819117288
and the i7 3770 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116502
is the xeon better or equal to the i7 because saving this money to put towards a larger gfx card like a gtx 660 or 7870 would be huge for me. i will be using it on a asrock z77 with 16gb of 1600mhz ram.
I'd also suggest the i7-3770. But get the " K " editon so the 3770K which means you can overclock your cpu. Also the reason you should get that over the Xeon , is that i7's a normally better rounded and it has a higher clock speed.
