BF4 Beta FPS problems
Smashing todd
120
Hello guys :) I'm having problems. My computer isn't the best but it SHOULD do better than this. In BF4 I get 20-30 FPS on ultra/high and 5-15 on lowest (wich is wierd, any solutions?). So my question is. Is there a problem or is my PC just not good enough? I run BF3 on high/ultra on 40-90 FPS 😛
PC specs:
2GB 7850 Sapphire OC edition (OC)
AMD FX-6100 3.3 GHz
8GB 1600Mhz RAM
Heard this as well. They do this to have a known working version with all components needed for online play. Newer versions still have bugs untested by the devs. Expect the FPS to be totally fine when the game is released. You should get pretty much the same, maybe 5fps lower than you do on BF3
This ^
Also, I remember reading somewhere that the beta isn't even the most current version of the game, it was just the one that was approved to be used as the beta.
Odds are, yes. It will vary from computer to computer even if someone has the same specs, they might get better FPS just due to a driver version or the programs their running ect. Just wait for the first update or so and your fps will begin to improve.
Hi. Had this issue. Did a lot of reading on this the past few hours, so I know a lot about it. First off, it's still the BETA, so we're all experiencing graphic issues. Also, last night their was a Nvidia Graphic Driver released to help BF4 optimisation. If you have that installed, it'll help with the rendering (especially in firefights). Secondly, I recommend you make sure you're overclock is stable (If you ARE Overclocking), and if your not you should be. Also, test with 3DMark to make sure your stable.
Otherwise, just sit tight till Nvidia releases a full driver update. It'll come soon, if you check out the Nvidia forums there are thousands of requests 😉
I'm seeing 95% cpu usage with i5-3350P. Seems like bottleneck, but what does everyone think? I know in 64-person server a powerful cpu is needed, but I thought this quad-core was pretty good. Do I need to upgrade to unlocked cpu?? Seems likely. I'm not sure this is only driver-related.
Win 7 Ultimate
i5-3350P quad-core
GTX 760
8 GB RAM
Actually, many people have seen a 95%-99% CPU Usage when playing BF4, your not the only one. Just don't make any big decisions until the full game is released or when a new driver comes out.
Thanks, Spinny! A lot of people with more powerful CPU's? In-game people are saying they are having NO issues with fps with more powerful multi-core cpus.
I mean, personally, I have a 3770k overclocked, And I'm having lots of issues (I have a 660ti and am upgrading to a 780 HydroCopper soon). So, I guess my CPU is considered a higher end CPU for gaming. Others have the same issues with this CPU such as my friend with SLI 680 FTW's. It's just all really messed up lol.
Thanks again! I've been hearing from AMD users that their 7950's are handling it well, but it's weird. Some other AMDers are having same issues. I'm trying an overclock on my locked CPU, but obviously not going to be able to oc too much. Guess I'll just have to accept it until launch, or on the off-chance that a patch will make a sig difference.
i purchased my new PC a week ago its not top of the range but im running on ultr with no problems or lagg or anything. and im playing from South Africa on american servers.
i did invest into a case that hides most of the cables and have 6 fans in the case with a fan controlelr to cool
My mate is on ultra but gen 3 processor and is havign these problems, the haswell (gen 4) could make the differance you need for BF4, this is my opinion that haswell helps alot.
I have also read peopel are on 32bit.. YOU HAVE TO BE ON 64BIT!!
intel Haswell I5 with standard heat sink
corsair 1x8GM gaming ram
Asus gaming motherbaord
Asus GTX680 o 2G (havent over clocked this or anythin)
Segate 2TB HDD 7200RPM (dont have a ssd)
You realize that Origin doesn't allow most downloads on 32bit now a days. I'm not sure what your point is....
Well, some people say AMD's are running together. I mean, it would make sense considering EA partnered with AMD over Nvidia this year, because AMD will be doing the chips for the Xbox One and PS4, because it'll be easier for EA to deal with the same company between PC, Xbox, And PS. That may not be the reason but it's likely a chance that they spent more time optimizing with AMD over Nvidia because of their large partnership.
Although no one probably cares, this is my plan to resolve this (Maybe you want to take a similar path). I've been planning to upgrade my watercooling to a custom loop from a H100i soon, so I figured since my 660ti wasn't doing to well with these next generation (BF4, ect.) games, and if I added another 660ti it wouldn't do much of a difference, why not just upgrade to a 780 HydroCopper. This way I can Watercool my card, and I shouldn't have any issues with VRAM.
Do you know anything about messing with the GPU buffered frame rates in Nvidia control panel? Would that potentially make a difference? I have an i5 3350 quad-core, and I didn't think that would be necessary. Any suggestions?
NONE OF YOU KNOW ANYTHING. AMD chipsets are not working. i5 low end do not work. Expect the patch release, will fix this. This is an AMD issue. All 6000 models are not working only the highest end 8 core is working right now. MAke the correlation: 10000000 AMD users cant play while i7's and i5's are doing fine mostly.
Ummm... get out if you can't stay calm. And man, I have an Intel i5-3570k and I can't play the game at all with the low fps. so NO it is not an AMD issue.
Your completely wrong. I don't feel like wasting my time explaining why. I just lost all my respect for you 😉 Low end i5's do work, but with lots of stutters. AMD Chipsets work with the earlier drivers. Thanks for your ignorant post.
will 4 Giga of ram effect in performance on that kind of card? with a processor i3-3220?..4 Giga normal ram..not DDR5 nor DDR3
i5 2500k @ 4.4, HD 7970 @ 1150. Played great Tuesday and Wednesday, took Thursday off, and today (Friday) I can't play. Ultra was running completely smooth other than small server lag at times, then today maybe 3 fps on ultra, and around 10-12 on low. Tried messing with Punkbuster as some of the servers say there's a known issue causing server problems, but nothing worked. Chatted with some other gamers who were saying something about CPU threads getting crushed. I uninstalled the game, and just did a fresh install so we'll see what happens.
Edit: Fresh install did nothing.
People, I think it just down to the fact that it is a BETA version. The optimization isn't quite the best. I know people with 1500 dollar rigs and they have the exact same issues we do, and some don't.
Conclusion: Your rig 'probably' is NOT the problem while the optimization of the BETA is.
What might help some of you is:
-Updating to beta graphics card drivers
-Disabling origin in-game
-Giving BF4.exe a high priority in task manager
And what helped me (I think it did a little) is closing your web-browser after successful launch.
Obviously try to stress your pc as least as possible and close unnecessary programs.
These thing MIGHT help, sometimes they do and sometimes not, it's just optimized very badly.
So be careful and think twice before upgrading your pc components!
yep, I see 100% CPU usage if I clock my I5-3570k at 3.4GHz or 4.7GHz with no change in fps!
I get 50-70fps with a single 7950 (1GHz) with some sudden drops to 5fps. Settings on Ultra with 2x MSAA, 1080p
Crossfire doesn't work, it crashes reporting low memory, or directX error, even when there's stilll 4GB free (I've got 8GB).
