BF4 Extreme FPS Lag - Even replaced CPU!
Hyphron
112
Hello, I have this problem with my new PC. My FPS drops from 65-70 to 15-20 for few seconds and then back to normal. This his happening every minute or so. I have tried pretty much everything and nothing helps.
Specs:
CPU: AMD FX 8350
GPU: gtx 760 2gb
Motherboard: ASUSTeK Computer INC. M5A78L-M/USB3 (AM3R2)
RAM: 16.0GB Dual-Channel DDR3 @ 800MHz
OS: Windows 8.1 64 bit
Your 760g motherboard isn't good for the 8-core cpus, they have weak vrms and will cause the cpu to intermittently throttle(where the fps drops are coming from) replace it with a better motherboard, You may also have to replace the case aswell since the good AM3 motherboard are all ATX and will not fit in a matx case. Here's a better motherboard and case(if needed).
[PCPartPicker part list](http://pcpartpicker.com/p/LT2ckL) / [Price breakdown by merchant](http://pcpartpicker.com/p/LT2ckL/by_merchant/)
Type|Item|Price
**Motherboard** | [Gigabyte GA-970A-UD3P ATX AM3+ Motherboard](http://pcpartpicker.com/part/gigabyte-motherboard-ga970aud3p) | $84.98 @ OutletPC
**Case** | [NZXT Source 210 Elite (Black) ATX Mid Tower Case](http://pcpartpicker.com/part/nzxt-case-s210e001) | $44.99 @ Mwave
| | **Total**
| Prices include shipping, taxes, and discounts when available | $129.97
are you sure this will work because i dont have a lot of money left and also how come it worked for like 1 month then?? thanks so much for the help btw
is there a way that i can check if its the motherboard just to be safe?
The behavior isn't normal which is why you're replacing the motherboard. The board uses a 4+1 VRM phase which is kinda low for a power hungry cpu like the 8 core fx series. To make it worse the vrms have no heatsink. The VRMs will get very hot and have a hard time powering the cpu and will cause it to throttle. BF4 will use a good amount of CPU even on lower graphical settings.
Well shit. Looks like you have 2 possible causes. Aerocool Vp series has problems with volatge regulation and ripple. The unit is built by andyson, whom also makes alot psus for Raidmax who is one of the worst psu brands available. It could be the motherboard, it could be the PSU, it could be a combination of both. Either way IMHO both should be replaced. Here is a new list
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard ($79.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($60.74 @ Amazon)
Total: $140.73
The PSU is smaller but is much higher quality and more than capable of running your system.
