BF4 Low FPS on Certain Maps
themaker123
13
Here are my specs:
AMD A8-6600k
Radeon R9 280
8GB RAM
1TB HDD
I seem to have pretty wildly different FPS on BF4 from map to map. I am able to run Operation Locker and other indoors maps at High-Ultra and get 60 FPS 1920x1080 with 64p CQ large, while maps such as Pearl Market with the same specs gets me down to the low 20s. I have checked my task manager and seen that pretty much all the time on any map/game with any settings I am maxing CPU on 99%. Is the difference in map complexity and CPU requirements what is causing this drastic FPS drop? is my GPU the limiting factor, or is the CPU the problem? Changing settings seems to not make a difference in maps such as Pearl. For some reason, BF Hardline can give me 60+FPS in any mode/game with no problem. Any suggestions?
Thanks in advance.
Actually, some maps require more rendering,that's where INTEL is better.
But still,you cant turn off unnecessary graphics options.
Moreover check that your drivers are updated.
