BF4 Low FPS problem
Mangamer
73
Hi there. These are my pc specs:AMD fx 6300 @3.5
Gigabyte 970A-UD3P
RADEON r7 265 Sapphire Dual-X
1TB WD Caviar Blue
Crucial Balistix 8gb 1600mhz ddr3
Corsair VS550
CM k380
Most of the time i play with 40 or 50 fps at recommended (high settings) but from time to time the fps fall to 10 or less, does anyone know why this is happening?
Ok I had the same problem, it's not your hardware, it's the server host. Go look for other servers and play on them for a bit and see if you have the same issue. If you do move on to the next server.
I would also recommend that you add those servers to your favorites 😉
Shalome!
Shalome!
