C curtogoli Reputable Aug 14, 2014 7 0 4,510 Aug 14, 2014 #1 I can't play BF4 on the lowest settings above 15-20 fps. Current rig: Core 2 Quad Q8200 2.33 GHZ 4GB DDR2 750Ti 2GB 1680x1050 Is the CPU the Bottleneck? or my GPU too weak?
Solution I I i7Baby Aug 14, 2014 That's too hot. Gaming it should be less than 60C for sure. Blow out your case to get dust build up out - especially fans, coolers and filters. If it's still to hot, re-seat your cpu cooler (Google it) If still too hot, buy a better cp cooler.
LucoTF Splendid Sep 6, 2013 6,414 1 27,960 Aug 14, 2014 #2 You CPU is a bottleneck for sure, but you should be getting at least 30fps with that setup even on bigger maps Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Aug 14, 2014 #3 Is your cpu running hot? Have you tried to overclock it? Upvote 0 Downvote
RobCrezz Titan Mar 14, 2013 19,077 99 75,190 Aug 14, 2014 #4 Check temps, even with them specs you should be able to play it fine Upvote 0 Downvote
C curtogoli Reputable Aug 14, 2014 7 0 4,510 Aug 14, 2014 #5 But I don't know why i am not getting 30 fps because I saw on youtube someone playing bf4 with q8200 and 650 on medium, and getting 45 fps minimum. Upvote 0 Downvote
C curtogoli Reputable Aug 14, 2014 7 0 4,510 Aug 14, 2014 #6 i7Baby : Is your cpu running hot? Have you tried to overclock it? no its running max 70 degrees if i play bf4 Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Aug 14, 2014 Solution #7 That's too hot. Gaming it should be less than 60C for sure. Blow out your case to get dust build up out - especially fans, coolers and filters. If it's still to hot, re-seat your cpu cooler (Google it) If still too hot, buy a better cp cooler. Upvote 0 Downvote Solution
C curtogoli Reputable Aug 14, 2014 7 0 4,510 Aug 14, 2014 #8 i7Baby : That's too hot. Gaming it should be less than 60C for sure. Blow out your case to get dust build up out - especially fans, coolers and filters. If it's still to hot, re-seat your cpu cooler (Google it) If still too hot, buy a better cp cooler. How many frames should i get on ultra if I buy a 4770k with my current GPU ? Upvote 0 Downvote
RobCrezz Titan Mar 14, 2013 19,077 99 75,190 Aug 14, 2014 #9 i7Baby : That's too hot. Gaming it should be less than 60C for sure. Blow out your case to get dust build up out - especially fans, coolers and filters. If it's still to hot, re-seat your cpu cooler (Google it) If still too hot, buy a better cp cooler. 70'c is fairly normal for a Q8200 in my experience and shouldn't be throttling. Upvote 0 Downvote
C curtogoli Reputable Aug 14, 2014 7 0 4,510 Aug 14, 2014 #10 RobCrezz : i7Baby : That's too hot. Gaming it should be less than 60C for sure. Blow out your case to get dust build up out - especially fans, coolers and filters. If it's still to hot, re-seat your cpu cooler (Google it) If still too hot, buy a better cp cooler. 70'c is fairly normal for a Q8200 in my experience and shouldn't be throttling. But if I buy 4770k, and play bf4 on ultra how many frames would I get ? Upvote 0 Downvote
