G
Guest
Guest
ok heres the symtoms docs:
had luvverly windoze98 on my pc, never had to reinstall it
decided last week to put windoze2000 on so that i could use more 3d apps
2k continually died on me and after my 5th reinstall of it i decided to go back to good old 98
problem is the nt file system didnt let me install it straight away, and 2000 has not got a dos os thats any good
then suddenly it wouldnt recognise my c: drive anymore
so i put the drive as a slave in another pc, and the c:\ partition was 0bytes (should be 10 gig) and d:\ was 10gig
i took the drive to my bro and he tried formatting c: from his pc, which worked
but this is where the problem lies...
i now have an extra partition for some reason after we formatted c:\ and d:\
so ive got c:\(0bytes) d:\(10gig) and e:\(10 gig)
i cant get rid of c:\ and i cant install windoze on a drive that has 0 capacity
i tried fdisk but it seems to freeze before i can do anything to the partition
anyone got any ideas of what i can do cos i need my pc back alive for the weekend
check www.shogoninja.freeserve.co.uk/drives.gif to see what i mean
ta in advance
ta in advance
