big problems
Eric
1,373
Archived from groups: microsoft.public.win2000.file_system (More info?)
im having big problems with my windows... last night i arrived at the sasser virus my comp started restarting randomly every once in a while.. 60 second countdown and all. now the comp (we have 2 stores and both main computers at both stores have the same problem) both comps at both stores across town are now taking like 20 mins to boot up . then when it does bootup i cant run the tool to remove sasser because now i dont have admin rights although im logged in as the administrator its like my rights are gone ... at both store... whenever i try to copy paste move access anything it hangs and i hafta push the restart button... this is insane i have to backup a particular file off this computer otherwise im screwed because if i dont have these user files that are saved on the computer thats like 2300 peoples information i have to reaqcuire.. which is bad.. really bad.. so any help as to how i can fix this would be great
This link may help.
http://www.sysinternals.com/ntw2k/freeware/ntfsdos.shtml
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
And after the horse has bolted, install a Firewall, ensure yr win* are
updated, and have a current AV app.
Or say by by to yr business!
"Eric" <anonymous@discussions.microsoft.com> wrote in message
news:2E0A0BFD-70A9-4290-9889-8879F4C3F0CA@microsoft.com...
Hey did you get an answer to your problem? It sounds like
you had the same results that I had when I tried to
manually delete sasser. I am getting a W2K is starting
progress bar and then nothing. I did not have the
patients to wait 20 min like you did.
>-----Original Message-----
ensure yr win* are
message
arrived at the
and both main
then when it does
i dont have admin
like my rights are
insane i have to
really bad.. so any
