Big Temperature differences between "MSI Command Center","HWMonitor" and "Ryzen Master Tool"
BNK4300
I've noticed in the last days, that my CPU was idling on quiet high temps (). Due to "HWMonitor". Today i downloaded some programs (MSI Command Center and Ryzen Master Tool). And the Ryzen tool says, that my CPU is running on much lower temps. Which value is right?
I'm using a bequiet pure rock slim, so temperatures of 30°C would be normal.
Idling temps
Load temps(prime95):
Thanks in advance,
Ben
one reason is HW monitor reading your package temperature from the looks of the MSI is picking up the same thing
AMD progrram im having difficulties with one that one
EDIT.... AMD CPU'd DO run hotter than intel
i would trust HW monitor more
