I recently built a new pc, put it together, and it posted. But, it also says cmos battery low at the bottom, so I bought new ones and switched them out. It still shows that the battery is low. That was problem one.
Everytime I go into bios setup and change the settings, I press F10 to save and exit, so the system can reboot and apply the settings. The computer reboots into a black screen. I just changed the boot order. USB>HDD. (Also, my motherboard did not show and boot priorities before, it just said disabled.)
Then the third problem is that when I manage to get it so that it allows me to pick what I can boot from, I chose usb because it had windows 10 on it. I get a black screen with a thick blue line at the top. Then the screen eventually turns completely black.
The final problem is that none of the settings save. Ever. Every single time, the settings change back to what it was before and I don't know why. Please help me.
Parts:
Processor: AMD FX 6300
PSU: EVGA 500W 80+ bronze
GPU: Zotac nVidia GTX 750 TI
Motherboard: ASUS M5A78L-M/USB3
RAM: Kingston HyperX 2x4 ddr3 1600 mhz
HDD:Western Digital WD10EZEX
Parts:
