BIOS dose not recognize second hard disk, please help.
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
BIOS can not recognize the second hard disk. I changed the cable from hard
disk to motherboard, Falsh the BIOS, jumper setting is correct, and hard disk
has vibration when window starts , so what is the problem? BIOS shows just
the first hard disk and shows NONE for the second one. any idea? Thanks for
your help.
Regards,
Faram.
How old is the pc and does the new bios support the size of hard drive you
are installing...? What is the size of the drive you are trying to install.
Do you get any errors, does your computer hang at boot up..?
"Faram" <Faram@discussions.microsoft.com> wrote in message
news:3675F758-2C82-455F-BA64-6B49FDD32D97@microsoft.com...
> Hi,
disk
for
> your help.
> Regards,
> Faram.
It is P4 and It should support 20 GB hard disk. When systms boot up there is
no error message and system boot up normally, but I windows can not see the
hard disk.
Thanks,
Faram.
> > Hi,
> disk
> for
> > your help.
> > Regards,
> > Faram.
For Primary Master, Primary Slave, Secondary Master and Secondary Slave
did you set each one for Auto in the Bios.
> Hi,
> disk
> for
> your help.
> Regards,
> Faram.
Hi Rich;
Yes, they are all set to AUTO.
Thanks,
Faram.
> > Hi,
> > disk
> > for
> > your help.
> > Regards,
> > Faram.
Hi,
disk
your help.
Regards,
Faram.
What's the make and model # of the 2 drives.
> Hi,
> disk
> your help.
> Regards,
> Faram.
Maxtor 541DX 5400RPM 20 GB
Model: 2B020H1
Thanks,
Faram.
Just another suggestion. Is the red stripe on the cable facing the white
molex power connector.
"Norm" <spamspam@spam.com> wrote in message
news:4vTkd.18643$8G4.892@tornado.tampabay.rr.com...
> Hi,
> disk
> for
> your help.
> Regards,
> Faram.
Yes, red cable is facing the white power connector, but the cable can't fit
the other way, any way.
> > Hi,
> > disk
> > for
> > your help.
> > Regards,
> > Faram.
Maybe your drive is DEAD.
Does it spin up when you turn power on?
Did you try to use is with different system? (just to verify drive)
news:ED8DE1F9-D2A7-4D51-8F7B-FF561CD27EEC@microsoft.com...
you
install.
is
the
> hard disk.
> Thanks,
> Faram.
> > > Hi,
hard
hard
> > disk
just
Thanks
> > for
> > > your help.
> > > Regards,
> > > Faram.
