Question Bios fan settings for my Gigabyte Aorus Ultra x570
holzl
8
Hello!
I really hope someone will help me with this. Gigabyte forum is apparently dead. So Tomshardware is my only option.
I own Gigabyte Aorus x570 ultra MB and currently I struggle to set fans, so temperatures and RPM would be normal.
Here is HWinfo of my sensors: ibb.co/DMDngZ5
Questions:
Does this look normal?
what is the first chipset measurement with 72°C?
My CPU_fan in BIOS (Noctua NF-A12x25 on Macho REvB cooler) is set this way: ibb.co/jg8Hqsw
questons:
  • is this OK, since RPM are still around 1000 RPM, even not fully loaded.
  • is CPU_fan control mode OK set to PWM?
Another question is regarding PCH fan.
RPM for that fan is always 1600RPM. If I change it in BIOS to Silent, RPM fall down, but temperatures increase to 55 or more degrees. So now I have it set to balanced and RPM 1600+. Is that OK?
Next question about SysFAN Pump:
I have set it to Normal, with control mode set to Voltage. Is that OK?
Any tutorial about this fan settings in BIOS or advice about this would be appreciated.
I don't use native SIV app for fans, since there I can not set PCH fan. So Bios fan setting is the only way.
Thanks for all help.
