BIOS (Gigabyte H110 MOBO) Problem With HDMI (No Post With CPU's Graphics Neither With GPU)
ChrisTsall99
702
Hello,
I got Gigabyte H110M S2H. I am trying to open bios when I have connected my HDMI cable but with HDMI Bios doesn't post (pc is working perfect with HDMI) I tried after that a VGA cable and BIOS post and everything works but the picture quality isn't that good.
So the question is ... if I will buy a dvi to hdmi (I cant find a vga to hdmi) adapter and connect my hdmi to the adapter and then the hdmi in my screen will bios post (adapter costs around 3 euros ~)?
I not using CPU's graphics... I am using a saphire r7 260x oc 1gb !
cpu:i5 6600
Don't tell me ways in order to open bios with hdmi I have tried everything !
Hi, any progress you find?
its connected to r7 ( I have tried and the cpu graphics but nothing at all)
Yeap I have tried everything a guy from a store told me that my Bios doesn't support HDMI
According to their website, your motherboard does support HDMI.
http://www.gigabyte.com/Motherboard/GA-H110M-S2H-rev-10#ov
What CPU are you using? There might be an issue if you are using a Kabylake CPU.
Hmmm I don't really know I have tried everything but bios doesn't post with HDMI
i already know that but thanks for your time ...even if i pull out the gpu and connect hdmi to motherboard bios doesnt post
I bought a GTX 1050 Ti 4GB OC and now it works !
