Hallo
I have a question.
I can't change the boot order in bios, tried Fn+Fn 5 and 6, + and - but it doesn't work, anyone have a tip?
Lenovo ideapad 500 - 15acz Win 10
Sincerely, Sten Gronberg
Hello and thank you for your reply
The problem is not that, getting into the bios, the problem is that I can't change the boot order, I have tried all that "should work" Fn+ F5 and F6 respectively. Very strange problem.
So are you trying to do a one time change to the boot order (using the boot menu) or permanently changing the boot order in the bios (UEFI)? Changing the boot order in the bios can be counter intuitive. As this video shows you have to move the cursor with the arrow keys (not the mouse) and than use the plus and minus keys to move the drive from its present position, up or down, to the position you desire, than save the configuration.
