M maxboy Distinguished Oct 16, 2010 102 0 18,680 Jan 17, 2017 #1 gigabyte B75m windows 7 Most Latest - Apply Boot option first --hard drive Fast Boot - Enable .. Pxe on Lan Disable And OS TYPE:: Setup Now.. Del Button No enter ,,F1 button No enter ... Windows 7 dvd İnstallation Error
jpatrick2 Respectable May 4, 2016 458 0 1,960 Jan 17, 2017 #2 I'm not really sure what you're asking. Are you trying to get into BIOS, but cant because you have fast boot enabled? Upvote 0 Downvote
Zerk2012 Titan Ambassador Oct 6, 2014 22,103 2,288 104,240 Jan 17, 2017 #3 If your trying to install windows on that then reset CMOS. Connect disc drive and drive to install windows only using SATA ports 0 and 1. Pop in the disc and start the PC. Upvote 0 Downvote
M maxboy Distinguished Oct 16, 2010 102 0 18,680 Jan 17, 2017 #4 Cause :: slow works solution: speed works or try ...buttons Bios No into or boot settings no into .. And bios wrong system settings computer startup speed,,, No into bios UEFI enabled Bootable cd No play..and Windows İnstallation DVD Error Upvote 0 Downvote
jpatrick2 Respectable May 4, 2016 458 0 1,960 Jan 17, 2017 #5 I cannot decipher...I give up. Sorry mate. Upvote 0 Downvote
M maxboy Distinguished Oct 16, 2010 102 0 18,680 Jan 17, 2017 #6 jpatrick2 : I cannot decipher...I give up. Sorry mate. Another one question How bios reset ? entry impossible..... Maype Reset Upvote 0 Downvote
Zerk2012 Titan Ambassador Oct 6, 2014 22,103 2,288 104,240 Jan 17, 2017 #7 You can unplug the power supply and take the battery out of the board for a few minutes. Upvote 0 Downvote
M maxboy Distinguished Oct 16, 2010 102 0 18,680 Jan 21, 2017 #8 Zerk2012 : You can unplug the power supply and take the battery out of the board for a few minutes. Solved :: Very very interesting 15 inc monitor on at,, "DEL" Key No in enter bios Settings 90's Model monitor "DEL" Key,,,,,,, enter okay bios settings;;; Very very surprising Ok solution,, 90's model monitor or clean keyboard Upvote 0 Downvote
