P Pramugan Prominent Jul 3, 2017 1 0 510 Jul 3, 2017 #1 bios reset even after battery replacement and jumper reset. asus mother board m5a78mlx
Solution kanewolf Jul 3, 2017 Seems pretty reasonable for the time to be lost when you take out the battery. Without the battery, there is nothing to power the internal clock.
kanewolf Titan Moderator May 29, 2013 38,666 3,814 156,790 Jul 3, 2017 Solution #2 Seems pretty reasonable for the time to be lost when you take out the battery. Without the battery, there is nothing to power the internal clock. Upvote 0 Downvote Solution
