Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.hardware.homebuilt (More info?)
Hello...I recently built a system built around the Biostar M7NCD-Ultra
and am having problems getting dual channel going. I'm running a
Barton 2500 at stock speeds (166 bus, although I have also run it at
200fsb, but that speed gives an occasional blue screen). RAM is two
sticks of 512MB PC3200 from Mwave.com (bundled with motherboard). I
have the RAM installed on channel A and B per the instructions, but it
still only operates as single channel. A reviewer on Newegg suggests
installing 1 stick on channel B, installing Windows XP and then
installing a stick onto channel A. This sounds crazy to me...anybody
else have to do this? What have you done to get dual channel working
that maybe I should try?
caheaton@netzero.net
