Question Biostar Hifi a70u3p --- No System Agent Config on BIOS settings
Sep 27, 2019
I wanna connect my 2 monitor separately to my GPU and Internal GPU at same time, But it needs to enable the internal GPU on the bios.. But I found out my board doesn't have System Agent does anyone know my tiny problem!
You might want to elaborate on your current system's specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
for us to understand if you can power up using your specs alone. Also include the make and model of both the displays you'd like to tether to the system. Check and see which version of the BIOS you're on as well.
