Hello there! I'm in deep sh**! Three months ago my old but good motherboard and processor past out. So I took my computer into the computer service. They put new motherboard, processor and memory in it. The MB is Biostar NF61S AM2 SE, processor is AMD Sempron LE-1100 1.91 GHz (not as much crap as it sounds like) and 1GB DDR2 TwinMos PC25300/667MHz. The comp is working fine, I mean I am going to upgrade it with AMD Athlon64 X2 4400+, a new graphic card, probably GeForce 8500gt 512MB, and 1GB more of the same RAM. The problem poped out when I tried to reinstall my Windows XP Professional bootable. I set everything right in BIOS (btw, BIOS is up-to-date) but it just won't boot from a CD. Then I "founded out" that my Pioneer 112D is not recognized in BIOS (and the HDD is set as Slave, not as Master as it should be, I think). Then I looked "under the hood" of my computer and I fouded that the MB contains only one IDE place to "stab" the IDE controler( HDD is in it), The optical drive is pluged into the PCI Sata Host Card in PCI_1 slot. Does anyone know what to do to reinstall my Windows, except getting my computer into the comp. service. And also will it help if I get my HDD to my friend so that he can format it, then to put it back into my comp. will it start automaticaly Windows XP install if the CD is in drive. Please don't hesitate to help!!!
Happy New Year!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
