I need a pc using Bitfenix's Prodigy case. The use is for med/light gaming
Budget: $500 max
Overclocking: no
OS: if you can add it, otherwise not needed
Monitor: no
Mouse: no
Keyboard: yes (does not have to be for gaming)
Wifi Adapter: Yes
Games playing: Portal 2, Minecraft, WoT, TF2 and Skyrim
Budget: $500 max
Overclocking: no
Monitor: no
Mouse: no
Wifi Adapter: Yes
