Bitfenix prodigy m cable management
Noah L
Commendable
Aug 20, 2016
23
I'm looking at buying the bitfenix prodigy m case, but I have a non modular psu. I was wondering if the case has anywhere to put the extra cables that is out of sight.
I have also been looking at the bitfenix aegis case, which seems to have more room, but I like the prodigy m better.
Here are my specs:
Asus Strix r9 380
Amd a10 7850k
Gigabyte ga-f2a88xm-dh3 micro atx
Kingston hyperX fury ddr3 1600 2x4gb
Kingston 120gb
Adata 120gb
Corsair cx-600
Thermal master tc102
2x corsair af120 led fans
Lg optical drive (Not essential)
Thanks.
Your PSU is Tier four PSU.
PSU Tier list: http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
For your build, i recommend a Seasonic M12II-520 EVO,
specs: https://seasonic.com/product/m12ii-520-evo/
It's fully modular PSU (Tier two) and far better than your Corsair.
But if changing PSU is out of the question then for your Bitfenix Prodigy M, you can zip tie your leftover power cables and rest them on top of the PSU and under the 5.25" drive bay. If you remove the 5.25" drive bay then you'd have more room for the extra power cables.
