BitFenix Prodigy (White) dust solutions
SashimiSensei
8
I would like to know what sort of dust prevention systems people have come up with for the White BitFenix Prodigy? I know the black Prodigy has a filter on the front intake, but the white does not. 3rd party retailers DEMCiflex make a filter kit for the Prodigy, but it's for the black model. http://www.demcifilter.com/c70/BITFENIX-PRODIGY.aspx
I don't really want my computer being murdered by dust but can't think how to plug that massive front intake?
Any good ideas?
Hi antiglobal. Thank you for your very helpful reply.
I don't recall saying that I thought the DEMCiflex product was worthless to me.
My point is that the Black Prodigy has a front panel that is, in its entirety, a filter. The DEMCiflex filter is made to cover that whole front panel. Now, if you knew anything about the White Prodigy, you would know that the front panel is solid, with a thin area running around the edge of the panel acting as air intake for the front fan. If I were to use the DEMCiflex filter on the white case, the filter would be covering nothing but solid plastic, while the magnetic strips that attached the filter to the case would be covering the air intake channel.
So yes, I suppose I was saying that the DEMCiflex filter was worthless to me. Though not for the petty, superficial reasons you were suggesting.
After not being able to find a solution like yourself I'm going to try getting 2 of the dual 140mm demciflex filters and removing the sheet then putting it behind the front cover on the fan grill using some magnetic tape. Haven't bought my system yet but am planning out everything down to the smallest intricacies and after 2 days searching I couldn't find anything so came up with this. Should fit behind that front grill and stop all dust :)
