Bizarre problem with a Realtek RTL8191S wireless card/RTL8191SU driver
awesomeperson451
Commendable
Oct 28, 2016
So, I seem to have run into a problem with my Realtek RTL8191S USB wireless card that did not exist until a couple of months ago- more than 2 years after I started using it. The problem is not constant- it seems to be triggered by rebooting my wireless router (either manually or via an automatic soft restart). The problem can only be 'fixed' by restarting the computer, and it won't resurface until the router reboots.
There are two symptoms that I have found so far- one is an extreme slowdown in network speed and an intermittent connection. The other is far stranger, and, despite the 10+ years I've spent working in IT, I have no idea what could be causing it. First off, it can only be observed while running a "ping www.example.com -t" command in the command prompt, and observing the ping times. Here's the pattern that emerges:
XML:
Reply from 2607:f8b0:4008:809::2004: time=18ms
Reply from 2607:f8b0:4008:809::2004: time=45ms
Reply from 2607:f8b0:4008:809::2004: time=56ms
Reply from 2607:f8b0:4008:809::2004: time=55ms
Reply from 2607:f8b0:4008:809::2004: time=68ms
Reply from 2607:f8b0:4008:809::2004: time=95ms
Reply from 2607:f8b0:4008:809::2004: time=98ms
Reply from 2607:f8b0:4008:809::2004: time=108ms
Reply from 2607:f8b0:4008:809::2004: time=129ms
Reply from 2607:f8b0:4008:809::2004: time=140ms
Reply from 2607:f8b0:4008:809::2004: time=146ms
Reply from 2607:f8b0:4008:809::2004: time=195ms
Reply from 2607:f8b0:4008:809::2004: time=185ms
Reply from 2607:f8b0:4008:809::2004: time=241ms
Reply from 2607:f8b0:4008:809::2004: time=213ms
Reply from 2607:f8b0:4008:809::2004: time=230ms
Reply from 2607:f8b0:4008:809::2004: time=234ms
Reply from 2607:f8b0:4008:809::2004: time=254ms
Reply from 2607:f8b0:4008:809::2004: time=261ms
Reply from 2607:f8b0:4008:809::2004: time=287ms
Reply from 2607:f8b0:4008:809::2004: time=296ms
Reply from 2607:f8b0:4008:809::2004: time=315ms
Reply from 2607:f8b0:4008:809::2004: time=349ms
Reply from 2607:f8b0:4008:809::2004: time=339ms
Reply from 2607:f8b0:4008:809::2004: time=351ms
Reply from 2607:f8b0:4008:809::2004: time=366ms
Reply from 2607:f8b0:4008:809::2004: time=378ms
Reply from 2607:f8b0:4008:809::2004: time=387ms
Reply from 2607:f8b0:4008:809::2004: time=404ms
Reply from 2607:f8b0:4008:809::2004: time=415ms
Reply from 2607:f8b0:4008:809::2004: time=423ms
Reply from 2607:f8b0:4008:809::2004: time=451ms
Reply from 2607:f8b0:4008:809::2004: time=457ms
Reply from 2607:f8b0:4008:809::2004: time=464ms
Reply from 2607:f8b0:4008:809::2004: time=494ms
Reply from 2607:f8b0:4008:809::2004: time=506ms
Reply from 2607:f8b0:4008:809::2004: time=520ms
Reply from 2607:f8b0:4008:809::2004: time=536ms
Reply from 2607:f8b0:4008:809::2004: time=557ms
Reply from 2607:f8b0:4008:809::2004: time=551ms
Reply from 2607:f8b0:4008:809::2004: time=577ms
Reply from 2607:f8b0:4008:809::2004: time=585ms
Reply from 2607:f8b0:4008:809::2004: time=609ms
Reply from 2607:f8b0:4008:809::2004: time=627ms
Reply from 2607:f8b0:4008:809::2004: time=634ms
Reply from 2607:f8b0:4008:809::2004: time=628ms
Reply from 2607:f8b0:4008:809::2004: time=659ms
Reply from 2607:f8b0:4008:809::2004: time=656ms
Reply from 2607:f8b0:4008:809::2004: time=670ms
Reply from 2607:f8b0:4008:809::2004: time=713ms
Reply from 2607:f8b0:4008:809::2004: time=701ms
Reply from 2607:f8b0:4008:809::2004: time=735ms
Reply from 2607:f8b0:4008:809::2004: time=753ms
Reply from 2607:f8b0:4008:809::2004: time=752ms
Reply from 2607:f8b0:4008:809::2004: time=750ms
Reply from 2607:f8b0:4008:809::2004: time=768ms
Reply from 2607:f8b0:4008:809::2004: time=797ms
Reply from 2607:f8b0:4008:809::2004: time=803ms
Reply from 2607:f8b0:4008:809::2004: time=820ms
Reply from 2607:f8b0:4008:809::2004: time=897ms
Reply from 2607:f8b0:4008:809::2004: time=855ms
Reply from 2607:f8b0:4008:809::2004: time=924ms
Reply from 2607:f8b0:4008:809::2004: time=875ms
Reply from 2607:f8b0:4008:809::2004: time=932ms
Reply from 2607:f8b0:4008:809::2004: time=901ms
Reply from 2607:f8b0:4008:809::2004: time=917ms
Reply from 2607:f8b0:4008:809::2004: time=919ms
Reply from 2607:f8b0:4008:809::2004: time=931ms
Reply from 2607:f8b0:4008:809::2004: time=947ms
Reply from 2607:f8b0:4008:809::2004: time=959ms
Reply from 2607:f8b0:4008:809::2004: time=22ms
Reply from 2607:f8b0:4008:809::2004: time=15ms
Reply from 2607:f8b0:4008:809::2004: time=14ms
Reply from 2607:f8b0:4008:809::2004: time=30ms
Reply from 2607:f8b0:4008:809::2004: time=33ms
Reply from 2607:f8b0:4008:809::2004: time=37ms
Reply from 2607:f8b0:4008:809::2004: time=61ms
Reply from 2607:f8b0:4008:809::2004: time=66ms
Reply from 2607:f8b0:4008:809::2004: time=79ms
Reply from 2607:f8b0:4008:809::2004: time=113ms
Reply from 2607:f8b0:4008:809::2004: time=122ms
Reply from 2607:f8b0:4008:809::2004: time=149ms
Reply from 2607:f8b0:4008:809::2004: time=152ms
Reply from 2607:f8b0:4008:809::2004: time=170ms
Reply from 2607:f8b0:4008:809::2004: time=193ms
Reply from 2607:f8b0:4008:809::2004: time=194ms
Reply from 2607:f8b0:4008:809::2004: time=212ms
Reply from 2607:f8b0:4008:809::2004: time=239ms
Reply from 2607:f8b0:4008:809::2004: time=245ms
Reply from 2607:f8b0:4008:809::2004: time=273ms
Reply from 2607:f8b0:4008:809::2004: time=291ms
Reply from 2607:f8b0:4008:809::2004: time=285ms
Reply from 2607:f8b0:4008:809::2004: time=301ms
Reply from 2607:f8b0:4008:809::2004: time=308ms
Reply from 2607:f8b0:4008:809::2004: time=332ms
Reply from 2607:f8b0:4008:809::2004: time=352ms
Reply from 2607:f8b0:4008:809::2004: time=356ms
Reply from 2607:f8b0:4008:809::2004: time=383ms
Reply from 2607:f8b0:4008:809::2004: time=398ms
Reply from 2607:f8b0:4008:809::2004: time=401ms
Reply from 2607:f8b0:4008:809::2004: time=435ms
Reply from 2607:f8b0:4008:809::2004: time=440ms
Reply from 2607:f8b0:4008:809::2004: time=438ms
Reply from 2607:f8b0:4008:809::2004: time=453ms
Reply from 2607:f8b0:4008:809::2004: time=484ms
Reply from 2607:f8b0:4008:809::2004: time=491ms
Reply from 2607:f8b0:4008:809::2004: time=495ms
Reply from 2607:f8b0:4008:809::2004: time=509ms
Reply from 2607:f8b0:4008:809::2004: time=525ms
Reply from 2607:f8b0:4008:809::2004: time=547ms
Reply from 2607:f8b0:4008:809::2004: time=549ms
Reply from 2607:f8b0:4008:809::2004: time=564ms
Reply from 2607:f8b0:4008:809::2004: time=592ms
Reply from 2607:f8b0:4008:809::2004: time=586ms
Reply from 2607:f8b0:4008:809::2004: time=629ms
Reply from 2607:f8b0:4008:809::2004: time=652ms
Reply from 2607:f8b0:4008:809::2004: time=658ms
Reply from 2607:f8b0:4008:809::2004: time=669ms
Reply from 2607:f8b0:4008:809::2004: time=699ms
Reply from 2607:f8b0:4008:809::2004: time=710ms
Reply from 2607:f8b0:4008:809::2004: time=722ms
Reply from 2607:f8b0:4008:809::2004: time=727ms
Reply from 2607:f8b0:4008:809::2004: time=748ms
Reply from 2607:f8b0:4008:809::2004: time=780ms
Reply from 2607:f8b0:4008:809::2004: time=799ms
Reply from 2607:f8b0:4008:809::2004: time=814ms
Reply from 2607:f8b0:4008:809::2004: time=822ms
Reply from 2607:f8b0:4008:809::2004: time=838ms
Reply from 2607:f8b0:4008:809::2004: time=854ms
Reply from 2607:f8b0:4008:809::2004: time=870ms
Reply from 2607:f8b0:4008:809::2004: time=877ms
Reply from 2607:f8b0:4008:809::2004: time=903ms
Reply from 2607:f8b0:4008:809::2004: time=907ms
Reply from 2607:f8b0:4008:809::2004: time=920ms
Reply from 2607:f8b0:4008:809::2004: time=957ms
Reply from 2607:f8b0:4008:809::2004: time=946ms
Reply from 2607:f8b0:4008:809::2004: time=958ms
(apologies for pagestretch)
Unplugging/plugging the network card back in does nothing. Neither does uninstalling/reinstalling/updating the driver software.
Running a ping test from my Galaxy S4 connected to the same network yields ping times that are consistently around 30ms, not increasing, decreasing, or displaying a pattern anything like the one I get on my computer.
Does anyone have an idea of what else I could try to get this thing to stop doing this? At this point, I'm rebooting my computer about once an hour, and it's getting quite annoying. I would rather not have to buy another network card, if possible.
Only properties available are: 802.11d enable/disable (currently disabled)
Beacon Interval - set to 100
Wireless mode- 802.11b/g/n, 802.11b/g, 802.11b - currently set to 802.11b/g/n
Unless there's a different properties menu besides the one under control panel - devices and printers - rtl8191s right click menu - properties - hardware - rtl8191su properties - advanced. Which, by the way, takes so many steps to get to, I assumed it would've been more helpful.
Network and sharing center from bottom right of screen, change adapter settings, double click on wireless card then click properties, not configure. This will show you the protocols being used. Make sure IPv4 is checked.
