Black ops 3 PC fps problems
Eli Stout
177
I'm getting really bad fps all of a sudden (10-20). It just started happening 3 days ago. I have a gtx 660 and I was playing at high settings, 1080p, 50-60 fps. All the tutorials for the fix tell me to change something in the config file but they're all from November and the config file has been updated since then. Thanks.
that is the issue, your GPU is not boosting correctly and is running at idle clocks.
Right click your desktop and go into Nvidia Control Panel, from there manage 3D Settings, go to Global settings and where is says Power Management Mode, select Prefer Maximum Performance.
Keep an eye on your GPU Temperature when you do this.
Hey,
Whilst playing can you open some monitoring software and see what your GPU temperature, GPU core clock, CPU temperature and CPU clock is.
If you don't have any monitoring software already, you can download MSI Afterburner: https://gaming.msi.com/features/afterburner
Also, were any changes made to your system just before this happened, and make sure you have the latest Nvidia drivers as the last ones were very unstable, causing an array of issues.
