Hello! I was playing rocket league a few days ago and my monitor suddenly went black and my computer shut down. I had GTX 1080ti installed in my computer for a week and after that I removed it and deleted the old drivers and installed my own GTX 980 and the drivers. My computer worked perfectly fine for the first 30 minutes and then this happened. When I start up my computer now my monitor goes instantly black after the POST screen and it says "no signal". After the POST screen my computer won't shut down so it "works perfectly normal without a display". My GPU fan is working perfectly even though my display has no signal. I can't access the BIOS because the display goes black after I would be able to access the BIOS. I have tried the same GPU in my other computer and the same problem occurs. My computer is working perfectly with integrated graphics and with AMD HD6950. Temperatures are fine. Please help me as soon as possible, this problem is really getting on my nerves! Thanks for your time!
CPU: Intel i5-8600K 3.6GHz [overclocked to 4.68GHz]
GPU: Nvidia GTX 980
MOBO: Asus PRIME Z370-P II
RAM: 16GB G.Skill Ripjaws DDR4 3200MHz
PSU: Corsair RM750W
SSD: Intel 512GB 760P Series
Monitor: AOC Gaming AG271QX
OS: Windows 10 Home 64-bit
GPU: Nvidia GTX 980
PSU: Corsair RM750W
