Hello,
i build my new rig a few days ago. When I play games (BF3, Anno 2070, LoL), the monitor often suddenly states "no signal" and there is a loud, buzzing noise from the speakers. When the problem occurs, the System doesn't restart, I need to reset it manually and boot again. There is no error message at all.
The time when the error occurs varies. Sometimes it happens after 30 minutes of gaming, sometimes after 5 hours, and sometimes, there isnt a problem at all (but thats rare).
The components are:
Mainboard: Asus p8z77-V
CPU: i5-3570K
Graphic: Sapphire HD 7870 OC
HDD: Crucial m4 128GB SSD
CPU-Fan: Noctua NH-UP12 SE2
PSU: Be Quiet! Straight Power E8 580W
RAMs: Kingston Hyper-X 8GB
(Antec eleven hundred + 4 Case fans, Sony R/W)
Nothing overclocked.
Currently, I am using the CCC 12.6 beta, because I hoped it would improve the stability of the system, but I have the same problems as with CCC 12.4.
I tested the System with Furmark + Prime95, temps were ok (55C CPU, 65C GPU) and the system performed stable while tested (5 hours of testing). Memtest stated no errors (after ~45 minutes of testing).
Any ideas whats happening?
Thanks for help in advance
The components are:
CPU: i5-3570K
