Blower Fan or Dual Fan?
Blower Fan blows the hot air outside of your case, so the heat doesn't accumulate in your case. But has disadvantage that the GPU runs hotter.
Dual fans does not blow the hot air outside, but provides better cooling on your GPU
If you only have 1 GPU, dual fan is better as it is better cooling for the GPU and it won't affect your other system much.
