Blu-ray compatiblity with monitor
Andrew Sotheran
59
My pc: http://h20564.www2.hp.com/hpsc/doc/public/display?docId=c03522894
Blu-ray drive: http://www.amazon.co.uk/Pioneer-BDC-207DBK-Internal-Blu-ray-Player/dp/B0083R9QFC/ref=sr_1_1?s=computers&ie=UTF8&qid=1419966916&sr=1-1&keywords=Pioneer+BDC-207DBK
Monitor: http://www.amazon.co.uk/Acer-S220HQLBrbd-21-5-Widescreen-Monitor/dp/B005QDCCP2/ref=sr_1_2?s=computers&ie=UTF8&qid=1418157656&sr=1-2
As I'm about to head off to University next year I want to take some movies to play on my pc, however it doesn't come with a blu-ray drive. I have found a good one and i already have the software that can run blu-ray movies Cyberlink media suite 10.
However i have been reading that only a hdmi cable with a montor with HDCP can play blu-ray movies, apparently if you run the player on a non HDCP monitor it will give you an error message.
Can someone clear this up for me, will i be able to watch blu-ray movies with my stuff above?
Ideally in a good quality.
TY for any help
Andy 😀
Your monitor must be it states this in the description
Full HD LED Monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced 1080p Full HD gaming, multimedia and productivity applications, providing advantages such as Blu-ray Disc console gaming or widescreen cinematic playback.
Ok.. Thats is basically telling me what HDCP is and what DVI is. Doesn't really answer my question.
Will i be able to watch blu-ray movies with my monitor through the dvi cable?
So it doesn't matter if my monitor doesn't support HDCP, cause i've read a few reviews where people are having error messages as their monitor doesn't support HDCP.
Full HD LED Monitor
Makes sense.. Amazon is always pretty limited on information but I did find a few sites that state that the monitor supports HDCP though Dvi:
http://www.cclonline.com/product/71177/ET-WS0HE-B01/Monitors/Acer-S220HQLBrbd-21-5-inch-Widescreen-Full-HD-LED-Monitor/MON0618/
http://www.novatech.co.uk/products/monitors/22inchmonitors/et.ws0he.b01.html
http://www.pcworldbusiness.co.uk/catalogue/item/Acer+S220HQLBrbd+-+LED+monitor+-+21.5%22+-+1920+x+1080+FullHD+-+200+cd-m2+-+1000000001+%28dynamic%29+-+5+ms+-+DVI-D,+VGA+-+black/P146348P
There were a few sites like scan and tesco which said it didn't.
^ Me basically clearing it up for myself as well 😀
TY SR-71 😀 <3
Get a DVI cable to connect two DVI things together.
I have had the same issue when I bought my Blu Ray optical drive to play my favorite movies on blu ray but unfortunately I couldn't get it to play on my monitor because it does not have HDMI , I even bought a VGA To HDMI converter but I still got the same error msg when playing blu ray , plus the quality was way way down when using the converter so I wouldn't play Blu ray using the converter even if I didn't get the error and could actually play the movie. My suggestion is to get a new monitor that supports HDMI . I am getting a IPS panel monitor since color quality is really important to me , specially for movies .
