Blue Green and Red RCA Cables?
Saturnity
521
So I have a subwoofer that has inputs that are the usual red and white, but the only good cable I have thats RCA or whatever is green blue and red, what colors go where??
The cable you have is for video when using Component connections, but are essentially RCA cables.
Doesn't matter which 2 you use, as long as you use the same on both ends. Go with Red is Red, and use Blue for White. They will work fine for Audio use.
