Question Blue screen problem help me attached dmp details
May 14, 2019
12
Microsoft (R) Windows Debugger Version 10.0.18362.1 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\051319-9515-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 17763 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 17763.1.amd64fre.rs5_release.180914-1434
Machine Name:
Kernel base = 0xfffff804478a2000 PsLoadedModuleList = 0xfffff80447cbd730
Debug session time: Mon May 13 14:14:48.425 2019 (UTC - 7:00)
System Uptime: 0 days 3:09:24.172
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
0: kd> !analyze -v
  • Bugcheck Analysis *
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
Arguments:
Arg1: 0000000000000030, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: ffff8080ec779180, The PRCB address of the hung processor.
Arg4: 0000000000000003, The index of the hung processor.
Debugging Details:
*** WARNING: Unable to verify timestamp for win32k.sys
KEY_VALUES_STRING: 1
PROCESSES_ANALYSIS: 1
SERVICE_ANALYSIS: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 17763.1.amd64fre.rs5_release.180914-1434
SYSTEM_MANUFACTURER: System manufacturer
SYSTEM_PRODUCT_NAME: System Product Name
SYSTEM_SKU: SKU
SYSTEM_VERSION: System Version
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: 3001
BIOS_DATE: 03/09/2016
BASEBOARD_MANUFACTURER: ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT: A88XM-A
BASEBOARD_VERSION: Rev X.0x
DUMP_TYPE: 2
BUGCHECK_P1: 30
BUGCHECK_P2: 0
BUGCHECK_P3: ffff8080ec779180
BUGCHECK_P4: 3
BUGCHECK_STR: CLOCK_WATCHDOG_TIMEOUT
FAULTING_PROCESSOR: 3
PROCESS_NAME: DCS.exe
CPU_COUNT: 4
CPU_MHZ: ffa
CPU_VENDOR: AuthenticAMD
CPU_FAMILY: 15
CPU_MODEL: 13
CPU_STEPPING: 1
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
CURRENT_IRQL: d
ANALYSIS_SESSION_HOST: DESKTOP-HGAUV2Q
ANALYSIS_SESSION_TIME: 05-14-2019 05:50:25.0437
ANALYSIS_VERSION: 10.0.18362.1 amd64fre
LAST_CONTROL_TRANSFER: from fffff80447aceba6 to fffff80447a557e0
STACK_TEXT:
fffff80449c6dba8 fffff80447aceba6 : 0000000000000101 0000000000000030 0000000000000000 ffff8080ec779180 : nt!KeBugCheckEx
fffff80449c6dbb0 fffff80447986df4 : 0000000000000000 0000000000000000 00000000000b190b fffff80446666180 : nt!KeAccumulateTicks+0x144c76
fffff80449c6dc10 fffff8044780c332 : 0000000000000000 fffff8044786fc48 ffffb6851be97680 0000000000000002 : nt!KeClockInterruptNotify+0x604
fffff80449c6df30 fffff804479d5195 : 0000001a76d89f22 fffff80447872850 fffff80447872900 ffff8080ecaf1280 : hal!HalpTimerClockInterrupt+0xf2
fffff80449c6df60 fffff80447a571da : ffffb6851be97680 fffff80447872850 0000000000000118 fffff80447872850 : nt!KiCallInterruptServiceRoutine+0xa5
fffff80449c6dfb0 fffff80447a57727 : 0000000000000000 ffffb6851be97680 fffff80447872850 ffffb98f943682d8 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
ffffb6851be97600 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
THREAD_SHA1_HASH_MOD_FUNC: 5e958d63ed6cce864bfe4c595207e0e484aa7e7c
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: a64f57604a1652c6bc6ee0bc46df3a70888cf2be
THREAD_SHA1_HASH_MOD: e2266a530ca7fbace00cfa9add8dc0ac4504d759
FOLLOWUP_IP:
nt!KeAccumulateTicks+144c76
fffff804`47aceba6 cc int 3
FAULT_INSTR_CODE: cb8b48cc
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!KeAccumulateTicks+144c76
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 0
IMAGE_VERSION: 10.0.17763.475
STACK_COMMAND: .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET: 144c76
FAILURE_BUCKET_ID: CLOCK_WATCHDOG_TIMEOUT_INVALID_CONTEXT_nt!KeAccumulateTicks
PRIMARY_PROBLEM_CLASS: CLOCK_WATCHDOG_TIMEOUT_INVALID_CONTEXT_nt!KeAccumulateTicks
TARGET_TIME: 2019-05-13T21:14:48.000Z
OSBUILD: 17763
OSSERVICEPACK: 475
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: unknown_date
BUILDDATESTAMP_STR: 180914-1434
BUILDLAB_STR: rs5_release
BUILDOSVER_STR: 10.0.17763.1.amd64fre.rs5_release.180914-1434
ANALYSIS_SESSION_ELAPSED_TIME: 1b625
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:clock_watchdog_timeout_invalid_context_nt!keaccumulateticks
FAILURE_ID_HASH: {95498f51-33a9-903b-59e5-d236937d8ecf}
I am running this through a debugger as we speak and will see if i can find what point the IRQL wasn't processed.
Are you still encountering an issue? Are you having any other issues after this BSOD? Or is it just a one off that you want to understand?
I have ran this through a debugger and found the following:
View full report here (including 3rd party drivers and now timestamps): https://pste.eu/p/5j1M.html
BugCheck 101, {30, 0, ffff8080ec779180, 3}
*** WARNING: Unable to verify checksum for win32k.sys
Probably caused by : ntkrnlmp.exe ( nt!KeAccumulateTicks+144c76 ) OR hal.dll
Meaning: The specified processor is not processing interrupts. Typically, this occurs when the processor is nonresponsive or is deadlocked.
It seems you have the most up to date BIOS. This is likely caused by a driver. This can be caused by Microsoft drivers not being up to date also.
This CAN be caused by a hardware problem also.
Are you running any OC at all?
Have you ensured all Windows Updates have been installed?
Have you updated your NVIDIA drivers? - Your NVIDIA audio drivers are a couple of months old but the Video driver appears to be up to date.
It will also be apt to wait for someone elses input.
@Colif @gardenman (please both of you tell me if you'd rather I not attach you to these threads)
May 14, 2019
12
1.yes i still facing this problem
2.no other problem i having only this issue blue screen or stuttering especially while on gaming or any multi tasking ,some times open the explorer its getting some time to read.
3.i do not over clock anything
4.my windows is retail version so its updating some times but i cant sure its updated everything.
5.yes my nividia driver is up to date but i m using asus xonar sound card so dont know and want nvidia sound driver .
6.i cant judge this problem what is causing ...if you want any other details i can provide help me
Thanks
May 14, 2019
12
Hey bro i got another BSOD problem DPC_WATCHDOG_VIOLATION
Here with i attached another .dmp file
https://drive.google.com/open?id=11Il_4hoOzqFrl9PabuO53lFjok3MsVuf
I'm putting this through the debugger now.
I noticed this crash occured whilst you were opening or running Darksiders. This could be to do with VCRuntime140.dll.
Do the crashes occur in certain circumstances? I.e. does it only occur when you go to play games for example?
I also notice this is an Exception rather than a straightforward bugcheck.
Have you ensured everything in Windows is updated?
Have you made any recent hardware changes? Can you also post you're entire system spec.
Have you run a FULL system antivirus / antimalware scan?
I would firstly recommend that your run an SFC/SCANNOW and a CHKDSK in an elevated command prompt.
Edit:
See report of UE4Minidump here: https://pste.eu/p/a174.html
THIS REPORT HAS FOUND AN EXCEPTION - EXCEPTION ANALYSIS PERFORMED
Probably caused by : VCRUNTIME140.dll ( VCRUNTIME140!MoveSmall+4a )
Just for the record, I don't believe this is the minidump relating to your WATCHDOG VIOLATION.
Your SFC found corrupt files.
You can look in the appropriate log files to see what it has repaired - if it's simple, then that could potentially be the cause of your problems. And the SFC should have repaired them, but we will have to see.
I would also run the previous recommendations in my earlier post:
Satan-IR
1,378
161
11,890
162
PC Tailor is right with that DLL being probably the cause. I ran it and get "Unable to verify timestamp for VCRUNTIME140.dll".
What is the latest MS Visual C++ Redistribution you have installed?
Installing the latest version or reinstalling if you have the latest might help.
Reactions: PC Tailor
Colif
its unusual for a dll to cause a bsod... in that I can't remember last time it did. Its likely a driver is at the heart of the problem still.
clock watchdog timeout is error called by CPU but not necessarily caused by it. It can be software or hardware.
Do you have AI Suite installed? Remove it, Otherwise I would use autoruns to disable ASio.sys from running at startup - https://docs.microsoft.com/en-us/sysinternals/downloads/autoruns
@PC Tailor should sort 3rd party drivers in date order by year, its generally older drivers that cause BSOD, its not often the new ones (unless they from Nvidia). Any driver prior to July 2015 isn't win 10, so could be the reason for crashes.
The drivers for the logitech wingman are all from 2010, I would try to get updates for them as they not win 10 drivers.
May 14, 2019
12
Edit:
yes still continuing this problem
blue screen or stuttering especially while on gaming and any multi tasking ,
i dont have any specific antivirus software only having windows defender still i dont scan entire computer (can i scan with windows defender or you recommend me some other)?
And i reinstall every VCredist till latest version
MY SPECS:
A-10 6800K CPU
A88XMA MB
DEEP COOL GAMEX processor cooler
G SKILL RIPJAW 2133 mhz 4GBx4=16GB RAM
corsair 550WATTS PSU
Zotac GTX 1060 6 GB GPU
Asus xonar DG sound card
Crucial MX 300 SSD
WD 1 TB HDD
TOSHIBA 1TB HDD (3 months before added)
LG DVD
May 14, 2019
12
This problem suddenly came at that time i dont have AI suite ,Then i format and reinstall windows 10 pro, after that only i install AI suite for monitoring CPU
OK again i uninstall AI suite and try
