I have recently started experiencing BSODs soon after booting my computer.
I followed the advice on here and did a clean install of my video card driver, but it hasn't fixed the issue. I have also tried running sfc /scannow as well as chkdsk /f /r.
Furthermore, I've used CCleaner to scan my registry, as well as deleting a swath of unused programs.
However, my computer still BSODs soon after booting, and BSOD instantly when I attempt to do a system restore or even see available restore points. The error is "system thread exception not handled (ntfs.sys)"
My computer is an MSI GT780dxr and it has an GeForce GTX 675M video card.
CPU: Intel i7-2670QM 2.2GHz
16GB RAM
Windows 10 64bit
Let me know if any more information would be helpful, hoping the community can help me solve this.
Apologies in advance if there is a solution somewhere and I simply overlooked it.
*update 1*
The computer doesn't restart 'randomly' anymore, so it appears the video card problem no longer exists. However, it does reboot when one attempts to interact with System Restore in any way, as well as Windows Installer (I tried to uninstall a program which opened Windows Installer).
*update 2*
I thought perhaps trying up install the latest update might help with the Windows Installer crashes. However, it crashed during that process...
*update 3*
The BSOD no longer happens during normal computer use. However, if I leave it and goes to lower power (not hibernation), it invariably crashes (BSOD, same error). Also, if I attempt to shut down normally, it will BSOD in the process...
16GB RAM
Windows 10 64bit
*update 1*
*update 2*
*update 3*
