blue screen while playing overwatch pls help
Hi, I ran the dump file through the debugger and got the following information: https://pste.eu/p/HSoV.html
File: 021718-23625-01.dmp (Feb 17 2018 - 14:37:47)
BugCheck: [SYSTEM_SERVICE_EXCEPTION (3B)]
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
gardenman: Multiple symbols errors.
Uptime: 0 Day(s), 0 Hour(s), 52 Min(s), and 37 Sec(s)
Only 1 RAM module was installed when this crash happened.
I can't help you with this. Wait for additional replies. Good luck.
Hi, I ran the dump file through the debugger and got the following information: https://pste.eu/p/lufJ.html
File: 021418-29359-01.dmp (Feb 14 2018 - 20:16:46)
BugCheck: [DRIVER_IRQL_NOT_LESS_OR_EQUAL (D1)]
Probably caused by: memory_corruption (Process: System)
Uptime: 0 Day(s), 0 Hour(s), 00 Min(s), and 17 Sec(s)
There was no BIOS information in the dump file which can sometimes indicate an outdated BIOS.
i dont overclock anything, and it usually takes about 20 minutes. my temps get up to about 60 degrees on my cpu and 70ish on my gpu
my bios were not up to date, ill update them and see if i still have problems
Well then your RAM should be fine. Hm, i would consider reinstalling windows, just to be sure its not that.
Otherwise maybe the GPU, CPU or your MOBO is faulty.
fresh install to fix a BSOD is a little extreme. As a 1st step anyway
what are the specs of the PC? The dump files aren't showing any details and the oldest file on your PC is from 2012 and appears to be a win 7 or Win 8 driver which could be cause of errors.
Driver dated Aug 28 2012 File name: dfx12x64.sys Description: Explore Systems Virtual Audio Device (Power Technology) - DFX12 Audio enhancer?
might want to updated Realtek HD AUdio drivers: https://www.tenforums.com/drivers-hardware/5993-latest-realtek-hd-audio-driver-version.html
Update Logitech Gaming software, I know there is a newer version than what you have.
The new dump file does contain the BIOS information. Here is the reading for it: https://pste.eu/p/ABAp.html
File: 021518-35109-01.dmp (Feb 16 2018 - 00:00:32)
Probably caused by: memory_corruption (Process: chrome.exe)
Uptime: 0 Day(s), 0 Hour(s), 04 Min(s), and 13 Sec(s)
