Blue screen with memory speed at 1333mhz
sprylog1
16
So, i have 4 gb ram, 2 x 2 gb 1333 mhz Patriot Memory PSD32G13332, my motherboard is a asrock n68-vs3-ucc, and in the website it says it supports up to 1600mhz, when i go into my bios to set the memory clock to 667, because on default, it's on auto at 400 mhz, i get a blue screen after a while, been getting different types of bosd's, i ran memtest for some time, and got no errors, so i don't know what else to do
Full PC Specs:
Windows 10 Pro 64 bit
4gb ram
500gb HDD
Geforce 210 1gb
AMD Atlhon ii x2 250 3.00ghz
yeah ok, but how do i know my current dram voltage? because its not showing in the BIOS, and can't find it in HWMonitor, the site says the default should be 1.50v, but i'm not sure, so should i change it to 1.53v?, because thats the only next one from 1.50v, actually in my bios, i don't even have 1.50 as an option, it's just 1.48v, than it jumps right to 1.53.
ok, i'm gonna try just with the memory voltage increased, not gonna change the cpu, if i still get BOSD, i'll try increasing cpu voltage too
