Question Blue yeti & Tonor Q9 Mic Noise
Jan 1, 2022
Hello all.
I'll start off with what mics im using and my pc specs.
Mics
Blue Yeti Blackout
Tonor Q9
Both mics are mounted onto a boom arm that's connectoed to a wooden table.
My room is silent i have no tv's or anything running.
PC Specs
OS: Windows 10
Cooler: Corsair H100i Elite
CPU: Ryzen 3900x
GPU: MSI RTX 3060
RAM: G Skill Trident Z 3600mhz
MB: x570 Aorus elite
Storage: 1tb Samsung 980 Pro
Storage: 500gb Samsunbg 970 Evo
Case: Lian Li Dynamic
Fans: 9 Corsair LL 120
So last night i was gaming with with friends and they said my mic (Tonor Q9) started making this weird noise. I did a mic test in discord and this is what it sounds like. (ignore the footsteps and door opening thats the game)
View: https://www.youtube.com/watch?v=P06pak1jV9k&list=UUMuaAp381NkWT7XyXCLDugg&index=1
This is the exact same noise my Blue Yeti started making after a couple of weeks of having it.
Things ive tried to fix it.
Messed with mic volume in windows around 80%-85% was the sweet spot for both mics.
Reduced the gain on both mics.
Tried multiple usb slots and removing all usb devices in my computer. (im using usb slots on motherboard)
All my drivers are up to date.
Wiped pc and did a fresh install of windows 10
Put fans on silent thinking the fans could be the issue.
I just cant figure out why both mics are making the exact same noise.
If the issue cant be fixed any mics you guys would recommend around £100 - £200
Thanks any help is appreciated and if you need any more info let me know.
Did you recreate your bootable USB installer using Windows Media Creation Tools prior to reinstalling the OS?
What BIOS version are you on for your motherboard? You forgot to mention the make and model of the PSU. Include the age of the unit as well.
