Question Bluescreen Problem
Aug 5, 2020
23
Hello there,
i had several Bluescreens.
Is a Windows clean install an option to fix it?
If yes:
Is there a recommended way to do it?
PC Tailor
Splendid
Ambassador
Welcome to the forums my friend!
Firstly if you would like help in seeing what the cause of the issue might be, please see this guide for information to include in your post as well as how to set up minidump files for us to analyse: https://forums.tomshardware.com/threads/handy-details-to-include-in-blue-screen-of-death-posts.3468965/
If you just want to jump straight into clean installing windows then here you go: https://forums.tomshardware.com/faq/how-to-do-a-clean-installation-of-windows-10.3170366/
Alternatively you can always try a Windows Reset if it will allow you to: https://uk.pcmag.com/windows-xp-2/118555/how-to-factory-reset-windows-10
However a clean install is NOT a guaranteed fix as it depends on what is causing the blue screens. However a clean install will often work when it just a software conflict.
