I just upgraded to an ax210 wireless card. After I installed the the Bluetooth drivers and rebooted my USB ports stopped working after windows 10 loads. They work just fine in the bios. Any ideas of what could cause this?
basically, go into windows control panel, select menu item to show hidden devices. This will show removed devices and you can delete the software for them. Then the last step would be to delete the pairings in registry.
