Question Bluetooth headphones audio help
Nov 17, 2024
Hi everyone
Before I get into the issue here is a link to all the parts I used : https://ca.pcpartpicker.com/list/nB9scx
So building a PC for the first time was definitely fun and worth it, but I am losing my mind over this one issue that I can't seem to find a fix on the internet for. I am using Sony WH-CH720N headphones connected via bluetooth to my pc. Yes it connects to bluetooth like normal and no issues on the connection part.
But, when I try and listen to something the audio is very inconsistent and it sounds like when you're talking to someone on the phone and they are breaking up. for a majority of the time. While other times the audio is perfectly fine and there is no issue with the sound for like a whole minute maybe even two. I am wondering has anyone else experienced this and is there a fix to my issue. Thanks for your support.
Tl;dr: Headphones connect to custom pc via bluetooth but audio sound like poor connection phone call for a majority of the time.
I thought the antenna was just for Wifi, I am so stupid. Thank you so much that seemed to fix the issue and the other minor issues with the bluetooth range. You are the best.
Reactions: dwd999
