Bluetooth Keyboard to PC Connection problem
SundownEditing
Commendable
Jan 28, 2017
57
Recently I bought a wireless mechanical keyboard, called a "Drevo Calibur 71-Key" (which I love) and I have an adaptor on my PC; for some strange reason, however, I can connect it with the wire that came with the keyboard, but when I use Bluetooth, my computer doesn't want to let it connect. Let me describe it in more detail.
I go to my Bluetooth settings on the PC and it appears, perfect. I can select it and have it connect, nice. But after I click connect, it has me type in a code(which changed each time) and press 'enter' afterwards. I type in the code, but when I press 'enter', nothing. I tried to even use a different keyboard to press 'enter', and even the on-screen keyboard, but all that does is hit 'cancel'...
I even attempted this on my iPhone, since my keyboard can connect up to three devices, and it works perfectly. I tried to disconnect all devices on Bluetooth from my PC, and I even tried to make the iPhone forget the keyboard and then connect it. I should also mention I tried to update the Bluetooth on the PC and that doesn't seem to be the problem...
Could anyone please help me?
I have solved it! YES!!
Appearently I had to go to Device Manager, Bluetooth, right click to properties, power management, and uncheck "allow the computer to turn off this device to save power". Appearently that disabled the keyboard from connecting! I'm so happy I solved it! :)
MERGED QUESTION
Question from SundownEditing : "Keyboard to PC Bluetooth Issue"
MERGED QUESTION
Question from SundownEditing : "Keyboard will connect to anything but PC, vise versa..."
