Can you suggest a Bluetooth pen with replaceable or refillable ink cartridge that I can use both
* for writing on paper, and
* with the cap on or pen tip retracted (the latter if retractable),
both recognizing the formula and creating the corresponding LaTeX script? I don't have a large budget but if an expensive pen has great advantages over a cheap one, I'll consider it. Preferably using a standard battery, eg SR621SW & AG1, so no need to solder if the rechargeable battery was to die.
Thank you kindly for your help
