Try them in a different device and see if they work fine. If you still have the problem, then the earbuds are the issue and probably need replacing. However, if they work fine on other devices, then the port on the device you were having problems through may be the issue.
In that case, that port would need replacing, or, if the problem is actually on a computer, you can get a 3.5mm to USB adapter and connect through that.
