Boom arm for rode nt usb
Mic weight shows up as 1.14 and 1.15 pounds.
Boom arm counter weights vary but you should be able to adjust the balance.
Not so much the weight of the mike but the required extension and then the balancing counterweight.
I would think that most boom arms would do the job unless really cheaply made.
Then the base needs to be heavy enough and have sufficient diameter to keep the boom from tipping even if balanced.
The bigger issue is how much abuse do you expect?
